Hi all...
Premiss (i will exclude forward voltage as i use them current regulated, but both of them have different voltages):
-1x 10W Blue LED (Current 1300 MAh)
-1x 10W Red LED (Current 1300 Mah)
The two leds are mounted on an old CPU heatink for dispersing the heat.
The situation is: I have a power supply of 15V 5A, and have two LM317, each driving a led. First thing i did is that i connected the LM317in parallel, and it wasnt working. Then, just for curiosity i connected the LM317 in series and it was working, so i left it like that.
Reason i'm using 2 LM317 is that the leds use each different voltages, and that LM317 handle only up to 1.5A .
Problem is that the circuit is not working as expected. isuspect that the RED led is drawing all the current and sabotaging it for the blue led which, after a while, dims and the red led gets all bright.
What do you think of my circuit? How could i connect two 10W leds in a better way? Do anybody know where the problem with my circuit? (Yes, i know i probably sound like a noob, but by making mistakes we learn a lot more )
Thanks in advance for any help
