So you need a 1500 watt supply that can work down to 300 watts and hold the 300V over that range.
I don't know your experience level. Read the data sheet attached and see if you understand what is happening in a boost power supply.
The step up power supply out of fairly common 1500 watt 24 volt DC to 220 - 240 volt AC inverter unit would do it just fine with a minor tweak to the 310 - 340 VDC rail voltage regulation feedback circuit to bring it down to 300 volts.
Odds are you wont build one cheaper than you will be able to buy an inverter and modify it for.
The IC can be about any "PWM" that will work in "boost" mode, and uses an external MOSFET.
The MOSFET needs to be a 100 amp part. The voltage rating depends on what type of circuit you build. (inductor or transformer)
This is not a beginner project. There are many places to go wrong. With average currents at 60A and peak currents near 70 or 80A you can't do this on a plug in bread board.
I think the transformer/inductor will have to be hand made and there aren't too many of us that do that.
This can not be built in an evening for $10.
Where are you?
understand but i just draw circuit shematic and the technician friend will assembly in the lab. can u draw that ? we have wind turbine we want to use that but we cant . and i dont understand so much to power electronics like this..
