I'm currently designing an HVAC PCB board and I'm having a hard time finding the right terminal that works to connect the wires to the PCB. The board is designed to work directly with the HOT line from an HVAC (24VAC) and it can tolerate a current of up to 20A (apparently some machines chew up quite a lot of power). Now I'm looking at choosing the right terminal blocks to hook the wire onto the PCB board, but I can't really seem to find something reasonable.
I found the following https://www.phoenixcontact.com/online/portal/us?uri=pxc-oc-itemdetail:pid=1730528&library=usen&tab=1 which is rated for 24A, but then the UL, cUL listings put group B @ 20A, but group D at 10A. I'm not sure what's the difference between the 2 groups. That said, CSA approval sets it to 10A. They're all rated for 300V.
I'm wondering if I'm not sizing it too high. ie: Because the ratings set this to >= 10A/300V and I'm operating on 24V, can I get a lower-rated terminal? ie: Is it more about Wattage than separate voltage & amperage?
Thanks,
Chris
Thanks,
Chris
