If they are mosfets and assuming GDS pin sequence, what is/are the through hole component(s) between the drain of one and the source of the other? Is it part of a switching supply?
If so, then the question becomes what made them overheat?
Thanks guys ill get back here after work with more info. The monitor doesnt turn on at all. No power light. But all fuses are fine and power is on the main power PCB but some lines on secondary control pcb says 12v but has no power. The rest of the board looks perfect so i assume a DARK burning orange spot is a good place to start.
Those green caps in the background look puffy in the picture. One of my Samsung 213T's went belly up and replacing six, similar looking caps is all it took. None of the caps had actually popped yet.
Yeah, those caps. Looks like you can even see brown crud residue from the electrolyte. Replace all six.
Look for low esr caps as opposed to general purpose for smps. The Panasonic FR series (and others) would work. Check the specs to match up the dia., height, and lead spacing of the caps you are replacing.
sometimes the failure of the capacitors causes further damage.
it's FAR more likely they are perfectly fine.
The further damage would most likely be those drivers.
Wait - what?![]()
That would be exceptionally unusual. The most common problem is corruption of the EEPROM
I don't know where you're getting your information
the ones I've dealt with had internal shorts (which is why they overheated and blew the safety) and the "most common problem" I saw was blown fuses and blown drivers.
