TiagoSilva
Hi you all
, well i have a machine that has a big transformer and the primary (input of the transformer) is controled by a power dimmer (with a Triac) and the secondary is in short circuit to heat a little piece of iron, well, and i have a small problem :wink: when other devices in the same power line are setted on they generate high peaks that in efect with the transformer's capacity, it generates even bigger peaks due to the transformer's discharge and that is burning a small protection fuse in the device in question, so what i need is a 220V AC Power Stablizer for some power i'd say some 1Kw, well, if you have such circuit schematic or solution or doubt
, just say
Bye, i hope you know hot to help me
Cheers !! 8)
Cheers !! 8)
