RobertaME
So normally I can solve most electronics problems on my own, but this one has me puzzled and I created this account to see if anyone else has some thoughts.
I have a 24-26vdc power source that checks for short circuits on the load line before applying full power by using a 3vdc testing voltage. I needed to convert this to a regulated 12vdc, so I bought a uxcell stepdown converter off of Amazon. After wiring, I powered up the unit and read the diagnostic display on the power supply which showed the load as being shorted out, so it refused to power on fully.
Trying to determine the cause, (and see if I got a faulty converter) I accidentally had the positive lead from the converter come slightly out of the wire nut connecting it to the power supply, which created some arcing between the contacts. Apparently, the extra resistance was enough to let my power supply think it had a good load on the line, so it kicked the power on and the 12vdc side of the converter started kicking out a steady 12.1vdc.
So here's my thinking... the converter when it first powers on is nearly a dead short until it starts putting power on the load side of the converter. So in order to get the power supply to start putting out power I have to add resistance between the power supply and the converter that will drop out of the circuit once the converter is running. I know there has to be a way to do this, but I'm just not seeing it ATM.
Attached is a simple diagram of the circuit. Any help would be appreciated. (I feel like there's a simple solution to this that is just escaping me)
