3 phase 3 wire measurement
ajitnayak87
Dear all,
I am trying to build 3 phase voltmeter that could measure L-L and L-N voltage during 3 phase 3 wire and 3 phase 4 wire connection. 3 phase 3 wire and 3 phase 4 wire connection are external connection.
as we know in 3 phase 4 wire we will get neutral reference so we can get accurate reading for L-L and L-N.
but in case of 3 phase 3 wire we dont have neutral reference .In this case it will be difficult to get gnd reference. I would like use both connection type in common circuit,
I have seen one of the product where they using V-X-M-H IC , can some one suggest me functionality of this iC. i have attached schematic for reference.
If any other suggestion with schematic will be appreciated. to differentiate 3 phase 3 wire and 3 phase 4 wire
  • Cadstar - Voltmeter.pdf
Can you just use some suitable resistors in a star formation to make a virtual neutral?
Dear sir,
I have attached some of circuit used and tested . I need help in to complete isolation and grounding part to MCU,
How can do this using differential amplifier circuit.
Circuit 1: purely based on voltage divider network and for delta connection. I wanted to use common circuit for both star and delta. how can i isolated the ground here.
Circuit 2: Using V-X_m_H ic OR TA1G label printed on it. i am curious to know what this ic will do??
is any one used
You might want to look at the following products:
https://datasheets.maximintegrated.com/en/ds/78M6631.pdf
https://www.digikey.com/reference-designs/en/power-management/energy-metering-for-ac/833
https://www.analog.com/en/products/ade7880.html#product-evaluationkit
https://www.analog.com/media/en/technical-documentation/data-sheets/ADE7880.pdf
I have tested with 3 phase 4 wire its working well, But how can i do calculation part in 3 phase 3 wire system in software
