You make the output pin of a device its disconnected 3rd state when you want to use the wire that its output is connected to by another IC's output.Marks256 said:Oh! I see now! Thanks! But then what is the purpose of the pin state? If it is so unstable, what is it good for?
YOu can use it for as an open collector output with the pull-up resistors so you can have a high voltage that is larger than the device's supply voltage.Marks256 said:Oh! I see now! Thanks! But then what is the purpose of the pin state? If it is so unstable, what is it good for?
