30ma SMD LED Resistor
ThomsCircuit
I did not know how to word the title but here is the issue. A member made this for me and said it will allow only 10ma to power the led regardless of the voltage. My project was a Buck converter with an input of 4.5-24 volts so that's the voltage range. Well I tested this on a breadboard with a led that had a 1.9fv. the mA must have been around 10-15 because it worked. My finished project is all SMD. The SMD LED is much higher 3.0v @ 30mA and it does not work in the circuit. I am pretty sure, OK absolutely sure, that the R2 needs to be lower than 62R. I just don't know what the formula is to figure this out. Thats what I need help with.
I also want the group to know that it has been 3 years since I asked for help with this BUCK converter project. I did have the board made and I soldered one up. My soldering is embarrassing, I forgot to order the correct pot, so I will do another after I solve the LED issue. Oh and the picture sucks too.
What works is when you have a problem to report all the node voltages clearly with labels or Ref Des. Even if you pencil on a schematic is OK.
Your LED may also be burnt out.
This is an active current limiter cct. Ic~0.62/Re= ~ 10mA depending on temperature and Q2 Vbe & base current.
The setpoint is Ic= Vbe(Q2)/R1 but Q1 needs to have enough current gain to work. When Q1 Vce = 0.7V is in the saturation region with low Vcc, hFE drops to about 10% of the max linear hFE.
Check that Vbe~ 0.6 with Ib=400 uA thus record Q1 Vc,Ve and Vf of diode.
Thank you. I understand most of what you replied and I will work on the node voltages. To clear up a few things. I believe the LED does work. But if you think the LED may be burnt then are you also saying that the 3.3fv 30mA LED should be working in this circuit? If that is accurate I could just change the LED however while it is difficult for me to remove the LED I did probe it with the MM on the board in diode mode. It read 3.0 and the LED glowed. So that led me to believe the LED is not burnt.
I took a white through hole led with a fv of 1.9 and just held it in place on the board over the SMD led and the white TH worked. It worked as expected as I adjusted the voltage up and down.
Here are the voltage readings taken at every node. I apologize if I missed any.
I think there is no connection between the collector of Q1 and the LED, or no connection between the Q1 and the positive supply, or the LED is connected the wrong way round. The circuit diagram you have posted will work if everything is connected as shown and all components work.
You haven't said what the voltage on the collector of Q1 is.
From the voltages on your circuit, there is 1.05 mA flowing through R1 and through R2. Q2 is not taking any current because there is not enough voltage between base and emitter to make it conduct. So Q2 is doing the right thing as the current is so much less than the design current.
The current flowing in R1 and R2 should therefore be flowing through the base of Q1. Q1 has a gain of about 100 so 1.05 mA in the base would allow 100 mA in the collector, but there fact that the base and emitter currents are the same means that there is no collector current. With no collector current and 1 mA base current, Q1 is saturated (turned fully on) and the collector voltage should be only a tiny bit higher than the base voltage.
That gives over 11 V across the LED and no current through the LED, which is what leads me to think that there is a problem in that area.
Thank you so much. The reading at Q1's collector is .076 v
That shows that the transistors and resistors part is doing what it should. That leaves just over 11 V across the LED, no current flowing and no light.
You said that the LED glows at 3.0 V, so it must be not connected or the wrong way round.
You are the smartest! I was misinterpreting the arrow on the bottom of the component.
