3720W power supply load transient testing rig...is this the cheapest/quickest way?
Flyback
We wish to do Transient testing of our 3720W power supply.
No_load to Full_load to No_load…..
Please could you advise if there is a quicker/cheaper way to do this than the attached? We need the three load switchs to switch at the very same instant.
The power supply uses Vicor DCDC modules.
  • 3720W LOAD Transient test.pdf
I think a simpler solution would be to use an optically coupled gate driver. That way you can go directly from your microcontroller to the LED of the opto.
Here is a sample that should work.
https://www.vishay.com/docs/84921/vod3120ab.pdf
You'll still need your independent, floating 12Volt supplies for the gate power.
