pkshima
I intend to make a 4 motor controller using 4 BA 6209
(datasheet **broken link removed**).
You will find an application circuit in there.
I just wanted to know if I could use just one zener diode for all 4 BA6209's.
Also I couldnt understand why the 10ohm resistor is going from Vcc to Pin 8 and not to Pin 7. I ask because Pin 8 is supposed to be set to output supply voltage and pin 7 to control logic supply voltage. wouldnt the 10ohm lower the supply voltage for the motors ?
