4 input XOR gate
fingers
Can anyone tell me a part number for a four input XOR gate - I can't find one. eg 74HC..
Wow hard one. You may have to make it.
Here are my search results
four input XOR gate
four input exclusive or
4-input XOR gate
4-input exclusive or
xor4
1134H 4-Input Exclusive-OR-Function Logic Gate General Micro-electronics Inc
http://www.americanmicrosemi.com/catalog/1134H.html
2134H 4-Input Exclusive-OR-Function Logic Gate General Micro-electronics Inc
PAL20X10a Programable Logic IC
http://www.tranzistoare.ro/datasheets2/12/1205394_1.pdf
XOR41 is a 4-input EXCLUSIVE-OR (XOR) gate with 1x drive strength
Here is how you make one.
Another way 4-input XOR
1 - sn7486, 2 - sn7410's, & 1 - sn7408.
You'll have 1-XOR gate and 2-AND gates leftover; but hey, they're cheap!
Decimals: 7 (0111), 11 (1011), 13 (1101), & 14 (1110) are problematic-with cascaded 2-input XORs; and therefore requires the extra logic.
I don't believe there is such a thing as a 4 input XOR function. An XOR function is by definition a 2 bit operation and while it can be performed on multibit variables (bytes, words, etc) it is still a bit by bit operation and any o 4 input bit gate function (with one bit output) will be some logic function other then a true XOR function ?
Lefty
True, it is, that XORs are two-bit operations, as in adders. Odd numbers of HI's in combination with a LO, in a cascaded XOR config, are always HI; and mathematically sound. I needed merely a circuit that wouldn't allow more than One of Four inputs to be HI, at a time--for Analog Multiplexer Addressing, and Idiot Proofing of illegal address modes. Not sure if that also is the configuration that "fingers" needed OR NOT.
Hi, I want to Design, lay out, and simulate a CMOS four-input XOR gate in the standard
0.25 micron CMOS process. You can choose any logic circuit
style, and you are free to choose how many stages of logic to use: you
could use one large logic gate or a combination of smaller logic gates.
The supply voltage is set at 2.5 V! Your circuit must drive an external
20 fF load in addition to whatever internal parasitics are present in your
circuit.
The primary design objective is to minimize the propagation delay
of the worst-case transition for your circuit. The secondary objective is
to minimize the area of the layout. At the very worst, your design must
have a propagation delay of no more than 0.5 ns and occupy an area of
no more than 500 square microns, but the faster and smaller your circuit,
the better. Be aware that, when using dynamic logic, the precharge time
should be made part of the delay.
The design will be graded on the magnitude of A ´ tp
2, the product
of the area of your design and the square of the delay for the worst-case
transition.
help me
hello @turnglqvtv
Did you solve this problem?
circuit.
2, the product
transition.
An online search located two 14-pin DIP devices, one each from Texas Instruments and Fairchild/ On Semiconductor. Both have identical pinouts, neither device is a CMOS.
