I am trying to use a crystal, but I can not get it to resonate properly, What is the best way to determine the cap values which are used in series with the crystal...for 40 KHZ frequency, Thanks in advance.
Are you certain you are using a fundamental mode, AT cut crystal ?
If the oscillator is running at a much lower freq than expected, it's possible that it's an overtone crystal and is resonating at it's fundamental frequency.
At 40 kHz, it won't be AT cut. AT cut crystals run at 1664/t MHz, where t is the thickness in µm
That makes a 40 kHz crystal about 42 mm thick, and it would have to be much wider than the thickness, so about half a meter in diameter.
40 kHz crystals are tuning-fork crystal, and they are never used in overtone mode.
I think it is in "Introduction to Quartz Crystal Unit Design" by Virgil E Bottom where the value is derived from the density and stiffness of quartz. Quartz is anisotropic so its stiffness depends on the angle of the cut. The electrical properties do not significantly affect the frequency.
