SimonTHK
Hello
So I try to figure out how my fryer power the heating elements.
It is a 400 v 3 phase deep fryer.
It has a mechanical thermostat. All 3 phases run directly through the thermostat. It powers 1 phase at a time with approx 5 degree´s difference.
It seems that no heat comes to the heating elements when 1 phase is powered through the thermostat. It gets hot when 2 phases are closed, and hot faster when 3.
I thought that 1 phase would power 1 heating element. But will this circuit diagram only power the heating elements, when atleast two are connected?
And is it correct that 1 phase closed through the thermostat, wont power any heating element?
I am simply not working enough with this stuff, also I dont really work with AC, mostly just dc![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks in advance.
I have attached the PDF manual. Page 14 has the circuit diagram.
Ive just come to the thought, that Ive might connected something wrong. Can I have currebnt running through the diode, if I connect some phases wrong, according to the diagram and "light diode" thingy called "Lamp" P1.
Thanks in advance.
