433MHz band filter simulation
micael
Hi im trying to simulate the operation of a band filter at 433.92MHz
So i was wondering if i have to use voltage generator with sine wave frequency at 433.92MHz to simulate the received signal.
Also the voltage after the filter still has 433.92 MHz frequency?
Has anyone tried this type of filter in practise? Any suggestions on the values of resistor and capacitors?
Presumably so?, but I never use simulators - bear in mind that a simulation will probably be quite different to an actual filter, due to stray capacitance and inductance in the hardware.
Yes, you're doing nothing to affect it.
That isn't an RF filter, you need inductors and capacitors (LC filters) not RC filters.
Hi
Can it be made by a Butterworth active filter circuit using wide band opamps such as AD8075 (550Mhz) and AD8074 (600 MHz) ? Also the Q factor and the bandwidth is important i think.
No way!
Yes, and use an LC circuit or a helical filter to do it.
