Kevin McDonald
Hi All,
First time post here. Hope you're all having a good weekend.
I'm doing a little project with a small clapper solenoid. It's one of the 5.5lb 12VDC, .25A 20mmDia. units sold on ebay. (ZYE1 P20/15). Though I don't have this one yet, so can give you the coil resistance, I'm working with one out of a printer with an 80.0 ohm resistance drawing .120A at 12VDC.
What I want to do is precisely control the cycle. It will be off normally, and when powered, might go through 30 cycles at 15hz. Or 600 cycles at 200hz. With a usable and reliable range of 5-200hz. It will never run for more than 3 seconds. And it will always have at least 5 minutes between uses. I'd like to build a circuit that allows as much adjustment as possible to allow me some fine fining.
I have a strong product development background, but am retired (Wish), well at least somewhat harmless with my little home arduino projects. Until it comes to what you guys do. I'm just getting too old to absorb some of this stuff, so I'm hoping someone can help me. Be happy to reciprocate with some hardware help.
So I'd like to drive this with my arduino PWM signal. All I can figure is to use an IRL540 with both a pull-up resistor across the Gate and Source, and a flyback 1n4001 across the Drain and Source. Or, across the two coil leads?
I know it can't be that simple. I really need this to run as cool as possible, and for years. In an enclosed box. I'm cool with spending component costs to do this right.
Thanks All, Happy Saint Patty's Day
KJM
KJM
