5 volt 1000 mA reduction from 12 volt supply
Schidtztorm
I'm trying to figure out a way to design a simple 5 volt 1000 mA regulator, or at least a way to drop the 12 volt supply down to 5 volts with 1 Amp. I don't have access to IC's or zeners, so I'll have to use voltage dividers to set voltage. And here's the real kicker! I have to make this with a FET. Enhancement/switcher type. But it's good for many amps, and up to 60 volts.
This is a type of contest between a couple of colleagues of mine and I'm setting them up for it. Lol. I just want to make sure I have a realistic design before I dish it out. They don't think it can be done without risks of frying the gadgets plugged into it.
Can anyone help me with this. If you need the FET info, I'll give it to you, or send you the datasheet. I'm hoping for a general design that will work on most FETs of this caliber.
The FETs are #1
Power mosfet N channel
6F433439
D30NF
SQM110. 06L
#2
High speed switching mosfet
H7P0601
4. K3
PO 24
P channel
10 amp!! You'll need a huge heatsink.
Edit, which is it? The title says 1A!
