+5v and -15v
Kryten
Hi
Would it be possible to connect a +5V and +15V to make +5V and -15V
like this? Whit both regulators 78XX
You cannot get minus voltage out of a regulator that has a positive voltage on the input.
Let us know what type of transformer you have and we can perform some tricks.
Apparently colin has never heard of switching regulators before =)
There are plenty of regulators that can provide a -15 volt supply from a positive input. Both regulators being 78XX though? No, you can't do that, they're linear regulators.
Of course I know about switching supplies. But he did not talk about this type of arrangement.
Hi
Are the +5V and +15V currently two separate power supplies.???
No its from the same PSU a 12V mouse kind. and im actually using LM317.
I guess i can use chargepump to make the -15V (ICL7662 is a nice one).
The ponit is that only have 12V to start with so after thinking i know that i cant use the two regs.
not without opening the unit and that is a lot of hassle at this time.
Other option is to use two of the powers to get +/-12V . would it then be possibel to get +5/-15V ?
Its to drive the EL on a GLCD ( I think it might be damaged anyways but i want to try it)
Do you have two power supplies on the bench.? if yes, what are their output voltages.??
