5v to 3.3v - SPI Tranlation
Noggin
Someone posted an article a while back which shows how to translate a SPI bus (or likely any bus really) from 3.3v to 5v so that one bus could work at both levels using only 1 fet and 1 resistor per line. I've been trying to find this document, but I have been unsuccessful. I have found Microchips 3.3 - 5v Tips 'n Tricks document, but I couldn't find what I was looking for exactly in there. I think I've replicated the circuit, but I wanted to compare it.
Are you talking about 1 pull-up resistor connected to the "output high voltage supply" and one pull-down FET driven by the input line? (Will only work for unidirectional busses...so for SPI it is fine, but not for I2C).
See if this fits your requirement.
yes, thats what I'm talking about. When I saw it, I didn't realize that it was unidirectional. The SPI bus I have implemented uses the same line to transmit and receive on so thats probably why it wasn't working out in my head.
