6 digit LED time totalizer
rajeev3602000
I need to schematic circuits , asm and hex build to 6 digit LED common anode display based time totalizer 9999.99 4 digit hour and 2 digit minutes with non-volatile memory .
I think there is something like that in the PIClist.
Have you decided what PIC?
A digital kitchen timer would count down from 99 min 59 sec and you need a timer that counts up from 0 to 9999 hours.
You can google for a 16f628 kitchen timer design in asm and modify the codes for it to count up. One I found was using 2x16 LCD so you need one using 7-segment LED CA design. Shouldn't be that hard to find.
https://www.google.com/webhp?source..._th=1&ie=UTF-8#q=16f628+4+digit+kitchen+timer
Just found this one but using 16f1828 instead of 16f628 and the language is BootC with partial assembly for the timer interrupt. You cam always use it as a reference.....
Allen
