I am trying to find a schematic for a 6 volt regulator for a motorcycle it is positive ground and it has a permanent magnet alternator magnet rotor and stator is coils of wire I am going to use a bridge rectifier radio shacks 25 amp version to change the output to DC but need to regulate the current charging the battery the alternator is only good for 10 amps so with the head lamp on ( law here in Va )mainly what I am trying to do is limit voltage to the 6 volt electronic ignition system ( Pazon brand) the voltage needs to stay below 7.5-8 volts any help is apreciated TIA
