duffy
Yes, here's a link to the spec sheet -
https://www.electro-tech-online.com/custompdfs/2009/02/slts059a-1.pdf
Pins are 1,2,3, left to right, from the front (check the diagram). The battery goes on pin 1, the charger goes on pin 3, ground (-) is common to battery, pin 2 on the regulator, and the charger.
Don't forget that 100µf cap from pin 3 to ground. You can ignore the other one, though.
