7 segment display using pic16f628
neelam29
hi frnz
m new to pic .m working on pic 16f628a .i wan to design a simple counter from 0-99 using two seven segment displays and a key.when a key is pressed the count should increase by one. can anybody help me out with the code.
neelam29 said:
hi frnz
Check my tutorials, which contain everything you need to do it - although you will have to use bits from various tutorials.
thanks but that was bit harder for me,cause m a new comer in feild of programming ,ur tutorial contains this type of programming using interrupts.i tried doing in a better and simpler way without using interrupts.
The interrupts make it easier! - it makes the multiplexing completely transparent to your main program. If you don't want to use interrupts you have the problem of maintaining reasonably accurate multiplexing whilst checking the keys, de-bouncing, and everything else!.
