7 segment fuel guage
zorbzz
Ok ill clear this up, ITS NOT FOR A CAR!
It uses car parts (plastic tank and fuel sender unit) but there is no fuel in it, it is water/detergent.
I want to use a PIC to measure the ohms coming from the sender unit and display it on a 7 segment display.
I know I could just get a multimeter but the table is in a dark area and LCD wont be visible.
This will give me a rough idea how much liquid is still in the tank.
Anyone seen a similar thing/project?
Really its just a Pic based ohm meter that uses 7 segments to display the ohms.
Thanks.
Given a choice, with a resistive fuel level sending unit I would think about using a LM3914 to drive a LED bar graph display.
Ron
Have you considered using a LM3914, this would give 10 indication levels, using regular LED's.
What is the min/max values of the resistive level sensor in the tank, [is it linear?] also what power supply do you have eg: 12Vdc...
"Drat Rons' already finished his second cup of coffee!"
You have to get up pretty early US EDT to beat Eric. :)
Ron
