8-bit up/down counter
ido_onLy
Hello all..
I'm a newbie, i'm so much interesting with PICmicro since I knew this awesome stuff..
I works as a technician at a medical supplier company in Indonesia.
I'd like to spend my time on holiday to do some electronic project
I need some advance, i need some code to make a PIC16F84A become 8-bit up/down counter with 3 button; count up button, count down button, and an set button (30sec turn off delay)..
I haven't much experience for PICmicros programming, I only got a JDM programmer, my first project was succeed to program a PIC16F84A become countdown timer from Stan Ocker's project.
Next month I've got plan to take a PICmicro training at certified microcontroller learning centre on Bandung.
Ganbatte..
Best regards
I'm not 100% sure what you want the "set button" to do, but everything else that you want to do is pretty easy.
You already know how to set the chip up, so I'll just cut to the chase and show the main code.
I don't think that you need to debounce your buttons, because they are just simple up/down counters.
Make RA0 through RA2 your button inputs.
Make all of PORTB your binary output.
You'll have to write your own delay routine (it's not hard at all)
This code is not tested, I just wrote it litterally off the top of my head. It's simple enough that you should be able to get it working
simply by seeing what it is supposed to be doing. I hope it helps
movlw 0x01
movwf mode ;This tells if your counting up or down, or not at all
;2 = counting up
;1 = not counting
;0 = counting down
main_loop
btfsc PORTA,0 ;this is the count up button
goto set_mode_up
btfsc PORTA,1 ;this is the count down button
goto set_mode_down
btfsc PORTA,2 ;this is the stop button
goto set_mode_stop
set_mode_up
movlw 0x02
movwf mode
goto count
set_mode_stop
movlw 0x01
movwf mode
goto count
set_mode_down
movlw 0x00
movwf mode
goto count
count
;see if mode was 0
movfw mode
btfss STATUS,Z
goto count_down
;see if mode was 1
xorlw 0x01
btfss STATUS,Z
goto count_stop
xorlw 0x01
;see if mode was 2
xorlw 0x02
btfss STATUS,Z
goto count_stop
;if all else fails, stop the count by default
goto count_stop
count_up
incf PORTB
call delay
goto main_loop
count_down
decf PORTB
call delay
goto main_loop
count_stop
call delay
goto main_loop
Hakuchukai,
When you post code, if you type
 before it and
after it then it will keep it's formatting like this,
		movlw	0x01
;2 = counting up
;1 = not counting
;0 = counting down
main_loop
		goto	set_mode_up
		goto	set_mode_down
		goto	set_mode_stop
[COLOR="Red"]; this will fall through and cause the code to count up.[/COLOR]
set_mode_up
		movlw	0x02
		movwf	mode
		goto	count
set_mode_stop
		movlw	0x01
		movwf	mode
		goto	count
set_mode_down
		movlw	0x00
		movwf	mode
		goto	count
count
;see if mode was 0
		movfw	mode
		btfss	STATUS,Z
		goto	count_down
;see if mode was 1
		xorlw	0x01
		btfss	STATUS,Z
		goto	count_stop
		xorlw	0x01
;see if mode was 2
		xorlw	0x02
		btfss	STATUS,Z
		goto	count_stop
		goto	count_stop
count_up
		incf	PORTB
		call	delay
		goto	main_loop
count_down
		decf	PORTB
		call	delay
		goto	main_loop
count_stop
		call	delay
		goto	main_loop
I think this code will count up when no button is pressed. See comment in red above.
thanks for the tip about the code tag.
Your right, it will fall through, but it's not an issue.
Mode is set to 1 at execution time. After that, mode can only change if you press a button. So it's not a problem
I made it quick and dirty, but it should work
No, first time through, if no button is pressed, it will fall through and set mode to 2.
yep, your right. That's what I get for coding quick and dirty with no testing.
In the place where it falls through just add the line "goto set_mode_stop"
That'll fix it.
Just to clarify... the point of this was to simply give Ido the basic idea of how this can be done. I figured there might be a bug or two, but if he plays with the code a little bit he'll get it working.
Here is a program for displaying 2 digits with up/down buttons. <snip: spam link deleted>
  • 2DigitUpDwn.txt
