ahmedragia21
Hi, How is it possible to use something like 89S52 to make a PAL video or VGA ? i know vga isnt possible cuz it needs more than 24Mhz .. also can i use only C for doing it ?
Why would you want to try this with a processor with so little power ?I want to do something like a pong game on the 8051.
You can run Pong perfectly well on a lowly PIC 16F84, so it doesn't have any massive power requirements. I built a Pong game years ago using one - just as good as the original arcade games.
I get to be wrong once in a while and I stand corrected.
But .... if I were to build a video project I would like some headroom.
Pong...ok.
</TITLE> <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" /> <title>ePanorama.net - Circuits
You need to be able to repeatably get an 11MHz pixel rate. You can use 1.1MHz if the smallest "pixel" you want is 10 pixels wide, and so on for straight PAL. I suspect pong was a larger number than that.
Yep! Poor pong, the atari 2600 killed her! Video table tennis at pizza placesYou've obviously seen Pong, the requirements aren't very demanding![]()
