R rgbutterfly New Member Nov 27, 2008 #1 I need help with building a project with the 8051. I need help with the assembly code. It is a final project. Any helpers???
blueroomelectronics Well-Known Member Nov 27, 2008 #2 Final project? Last one ever? Going on to farming?
3v0 Coop Build Coordinator Forum Supporter Nov 27, 2008 #3 rgbutterfly said: I need help with building a project with the 8051. I need help with the assembly code. It is a final project. Any helpers??? Click to expand... I want to know how you got to your final project and still need help with assembly code. What class is this for ?
R rgbutterfly New Member Nov 29, 2008 #4 8051f330 with Assembly Code This project is for my Digital 2 project at SPSU in Marietta, Ga. I wanted to create music with this microcontroller. I must use this microcontroller and assembly code for this project.
blueroomelectronics Well-Known Member Nov 29, 2008 #5 What part of the code are you having problems with? Can't believe they still teach the old 8051 in the USA.
3v0 Coop Build Coordinator Forum Supporter Nov 29, 2008 #6 Remeber that for notes duration = cycles * period A note with a higher pitch requires more cycles to get the same duration as a note with a lower pitch.
