mstechca said:I bought an 8088 IC, and when I looked at the datasheet, it shows that 8 data lines can be used as address lines. In simplest terms, exactly when do I treat the lines as address lines, and when do I treat them as data lines?
as electronist said the ALE pin (tells you/and is used to signal your support circuitry) when the lower 8 pins of the address bus are in fact addressesmstechca said:I bought an 8088 IC, and when I looked at the datasheet, it shows that 8 data lines can be used as address lines. In simplest terms, exactly when do I treat the lines as address lines, and when do I treat them as data lines?
mstechca said:Thanks.
Nigel, I'm not trying to make a super-gigantic 8088 computer system.
I want to be able to wire an 8088 to an LCD, some memory modules I have lying around, and to a data source (eeprom or my parallel port of my PC).
Not exactly. That problem was fixed.If this still just trying to get an LCD to work from your PC?.
mstechca said:I thought an 8088 was a good choice because I have extensive software programming experience with it and it is well known.
as for the PIC's, They might be more expensive because they are "microcontrollers". right?
upand_at_them said:PIC16F628 (far far superior and easier).....$3.69
mstechca said:Sayal Electronics Canada:
8088 - $3!
I saved probably $1 or $2.
My god, America is expensive to me. Thats cuz I'm canadian!
Nigel Goodwin said:upand_at_them said:PIC16F628 (far far superior and easier).....$3.69
I think that's a little harsh! :lol:
You can't really compare them as they are very different devices, the PIC is a micro-controller, and the 8088 a full micro-processor - the 8088 is intended to be a small part of a large complete computer system, where the PIC on it's own is a small complete 'computer system'.
