9pin serial connector for breadboard
dak246
Does anyone know where to get one of those 9pin serial connectors(subd?) specifically for a breadboard, or a way to connect one to a breadboard. The ones i have are pcb mount but the pins dont conform to my breadboard so it doesnt fit, not to mention i had to tear of the solder lugs to even try and force it to fit. Can anyone help me out?
you could allways take the breadboard apart.. if ya look under it you will see rows of clips...i soldered two 25 pin connectors on my breadboard this way...
just snap off 9 pins from one of those 1-row breakaway pin headers, and solder wires to a d-sub connector. or if you want something a little more solid, do it on a perfboard or etch an adaptor board up if you want something more polished looking and permanent.
I already have the pc mount ones and like Plot said the pins are offset so it doesnt fit. Crust do you know where i can find one of those old cards? If i cant find one of them ill just solder some wires to the pins like everyone else suggests. Thanks for the help.
crust said:
on the old i/o cards for PCs the serial port usually was a crimp type with a header on the other end. Those headers fit perfectly into breadboards.
really... that's very interested... now i have a reason to start salvaging old motherboards.
not necessairly perfect, they are the dual row headers, (0.1" spacing between all the pins, like a connector for a hard drive). so no matter how you connect it, you'll always have 2 pins connected to the same 5 pin row. (you need a 0.3" spacing between the rows to be able to connect it like an IC). I believe there was a topic a couple weeks ago talking about this problem.
At least this is how the cables were on all the motherboards I salvaged. (and I've salvaged quite a few)
