A/D etc..
TKS
10bit A/D
could some one explain me what they say whit this??
is this simple de accurancy of reading of a voltage..???
for example.. 1,236599875465 volts..??/
and what means 10MIPS
does this mean that is can do 10milion times a second one command.???
TKS
TKS said:
10bit A/D
No, it's the resolution of the converter, and refers to the number of bits (binary) used - so 10 bit can go from B'0000000000' to B'1111111111'. which is 0-1023 decimal. An 8 bit A2D goes from 0-255.
MIPS is 'Million Instructions Per Second', it's likely to be quoted using the fastest command the processor can execute (usually different commands take different amounts of time).
A/D
soow if i want to measure very accurate a voltage should i then make the sheme soow that is use low voltages..???
for example 1,236
and not 23,35 ??
or can you give a good example, i will take a look @ your site (i allready imagine that you forward me to it.)
TKS
Re: A/D
for example 1,236
and not 23,35 ??
TKS
Yes I would :lol:
My latest tutorial is about using the 10 bit A2D in PIC processors, and I discuss the reasons behind the choices I make.
Basically with a 10 bit A2D you potentially have around 0.1% resolution, you can scale the input to give any voltage range you want - but the output will always be 0-1023, you can multiply/divide this to give the correct voltage readings.
While it's potentially 0.1%, you're not going to achieve that in practice, for that matter how would you calibrate it? - but generally that degree of accuracy isn't required.
ok.
a 10 bit a/d is 2^10=1024 levels
so if your input range 0v-5v, you divide 5 by 1024 = 4.88mv per level
by having a higher bit rate you reduce you QN ratio.
that is the errror due to rounding the voltage level tothe nearest level.
we a/d you can usually set a refence level to set you range.
