Speakerguy
Active Member
Hey guys,
I am using the L6384 600V half bridge driver. It is fed power from the HV line through a resistor to the VCC pin which has an internal clamp to set the voltage to ~15.6V typ @ 5mA, and the absolute max current it can handle per the data sheet is 25mA. I am using isolated and rectified line voltage (170VDC here in the US). Here is the half bridge driver data sheet:
http://www.stmicro.fr/stonline/products/literature/ds/5651/l6384.pdf
I want to supply it with enough current to do it's job, as well as POSSIBLY feed an optoisolator.
What wattage and size resistor would you use? I've done the calculations myself, I just want a completely independent verification for safety purposes.
