A6 in 16F628 givinh 2.4v !?
aljamri
for a simple project, I'm using PortA as switch ( following NG switch Tutorial 2.2 ), everything is working o.k., except for A6 is giving 2.4v where as all the other switches pins are getting 5V before the switches pressed. The micro controller interpret it as the key is pressed.
the same pen can be used as OSC2 and CLKOUT, but I'm not using any of theses features. is there any thing to be checked in the initial setup.?
I've used the switch board according to Tutorial 2.2.
Thanks colin55, you've made me to change the cofig word, which is 0x3D18 originally in the tutorial into the following:
__config _BODEN_OFF & _INTRC_OSC_NOCLKOUT & _CP_OFF & _PWRTE_OFF & _WDT_OFF & _LVP_OFF & _MCLRE_OFF
The program know is working fine. Thanks for your help.
