About 500 kb program
Suj
My executable is about 500 kb, I do not know what kind of microcontroller is able to run it, please help. Thank you very much!
Either you need to optimize, or move to a different micro.... The 8051 has a 16 bit address so the MAX addressable size is 64K...
What makes the executable so large.... When I used to write LARGE programs on the XT PC I would be lucky to see 200K..
If you create some sort of "Off chip" system for all the "constant data" will the exe be a smight smaller???
Thank you very much. The calculation's complicity made my application so big. I have optimized it but got not much improvement. Would you please tell me what else MCU I can use for such kind of big program?
The 32bit micro's will be the way to go... Huge calculations would probably be too much for an 8 bit..
The pic32 has variants that can handle 2Mb of flash... But maybe a 16bit DSP ( 512kb ) would do....
What sort of calculations??? There are ways around certain mathematical calculations..
It is solving a ten variables non-linear equations using Newton's Iterative method as the derivatives are easy to calculate, and classic Chord method as its code simpler, both generates the executable of almost the same size. I do not know any other way better.
I know very little about MCU and nothing about pic32 and 16 bit DSP. Would you please recommend some readings about them for me? Thank you very much.
I can't recommend anything until I know what you are doing..
How do you know the code size BEFORE compilation... Have you compiled this code in windows?
Embedded code is tighter... Look over at MikroElectronica... They support MANY micro cores... Look at the math libraries to see if you can use their stuff... Loads of 32bit examples to view..
Yes, I compiled and built it with code::blocks c++ compiler in my windows 8.1.
Using C++ in embedded systems is an extravagance I rather not take.. The overheads outweigh the efficiency too much...
Tight code!! Well very well optimized code... Embedded C tends to optimize to levels not seen on PC's..
Perhaps a Microstick II DM330013-2 , it will support a range of MC mcu's 16 and 32 bit up to 256k code , just add MPLABX and toolchain . will get you started for little outlay.
What is worrying is once he has a micro running with soo many calculations on a mere micro, I think speed will be an issue... A Pentium quad core 64bit ( probably running at 2.4Ghz).. vs a LPC or pic single core less than 200Mhz..
Wouldn't bother!!!... I think you should be looking at a tiny PC 3,5" form factor... Or running it on a PI
