about PIC18 assembly code
fengshao
Hi everyone ,recently i got some code for my demo board .bt i met some part dont understand
Initialize
	bsf		STATUS,RP0		; bank 1
	bcf 	TRISC,1			; Output: RC1
	bcf 	TRISC,2        ; Output: RC2
	movlw	b'00001111'		; Outputs: RD2,RD4-RD7
	movwf	TRISD
	movlw	b'01110001'		; 8Mhz
	movwf	OSCCON
	movlw	b'00001110'		; enable AN0
	movwf	ADCON1
	movwf	b'00000101'		; Fosc/16
	movwf	ADCON2
	movlw	0x3F			; 31.2 kHz PWM
	movwf	PR2
	movlw	b'00000000'		; 1:2 prescaler for TMR0
	movwf	T0CON
	bcf		STATUS,RP0		; bank 0
	clrf	PORTD			; turn off windings
	clrf	PORTC
	movlw	b'00000001'		; left justified, AN0 selected, module on
	movwf	ADCON0
	movlw	0x07
	movwf	CMCON			; turn off comparators
	clrf	CCPR1L
	clrf	CCPR2L
	movlw	b'00001100'		; pwm mode
	movwf	CCP1CON
	movwf	CCP2CON	        ; turn on PWM
	bsf 	T2CON,TMR2ON	; turn on Timer 1
	bsf		T1CON,TMR1ON	; turn on Timer 1
	clrf	State			; initialize motor state pointer and duty cycle
	clrf	Index			;  index pointer
	clrf	Mode
	clrf	ADRESH
	movlw	1
	movwf	StepModeScaler
	movwf	Counter
	clrf	Speed
	clrf	ButtonState		; initialize button state
Main
 	[COLOR="Red"]btfss	INTCON,TMR0IF		; Wait 2.5ms
	goto	Main
	bcf		INTCON,TMR0IF[/COLOR]
   	call	ButtonPress		; Call the button press debounce routine
	btfsc	STATUS,C		; The carry flag is set if a button press just occurred
	incf	Mode,f			;  Change to the next state  when a button press occurs.
the 3 red color line ,when i add ,the whole programme will always loop there ,when i delete these code ,my motor can run ,someone can help
  • stepper.zip
All you are doing is looping the btfss statement with the goto on the next line.
You probably want the goto statement at the end.
you need to show way more code than that.
How is the timer set up?
TIP:
When you first start a interrupt you should clear the associated flag right after you enable it.
You need to turn on Timer 0,
	bsf 	T0CON,TMR0ON	            ; turn on Timer 0
Main
	goto	Main
	bcf	INTCON,TMR0IF
lol dude where is you ISR? Timer Intterupt? You need that in order to clear it in the interrup itself.
When you have a interrupt it jumps to s special location:
Most Pics have is like:
High Priority = Address 0x08
Low Priority = Address 0x18
Need more code. Somewhere there you sure have something similar to :
	ORG	0x0000
	bra    Init    ;where ever you program starts.
	ORG	0x0008
	bra	HighInt        ; If using a high interrupt if not then 0x0018
HighInt:
        bcf    INTCON,TMR0IF
	retfie    FAST
	END
not tested but something like:
	ORG	0x0000
	bra Initialize
	ORG	0x0008
Initialize
	movwf	TRISD
	movwf	OSCCON
	movwf	ADCON1
	movwf	ADCON2
	movwf	PR2
	movwf	T0CON
	clrf	PORTC
	movwf	ADCON0
	movlw	0x07
	clrf	CCPR1L
	clrf	CCPR2L
	movwf	CCP1CON
[COLOR="Red"] 	bsf 	T0CON,TMR0ON	; turn on Timer 0
	movlw	0xE0
	movwf	INTCON			;Turn on Timer0 Interrupt .
	bsf		INTCON2,TMR0IP	;Make timer 0 high priority. [/COLOR]
	clrf	Mode
	clrf	ADRESH
	movlw	1
	movwf	Counter
	clrf	Speed
Main;[COLOR="Red"]
 	btfss	myFlag,0		; Wait 2.5ms
	goto	Main
	bcf		myFlag,0		;Clear the flag for next time[/COLOR]
[COLOR="Red"]HighInt:
    bcf		INTCON,TMR0IF	;
    bsf		myFlag,0 ;  Create your own flag
	retfie	FAST[/COLOR]
	END
	ORG	0x0000
	bra Initialize
	ORG	0x0008
Initialize
	movwf	TRISD
	movwf	OSCCON
	movwf	ADCON1
	movwf	ADCON2
	movwf	PR2
	movwf	T0CON
	clrf	PORTC
	movwf	ADCON0
	movlw	0x07
	clrf	CCPR1L
	clrf	CCPR2L
	movwf	CCP1CON
	movlw	0xE0
	clrf	Mode
	clrf	ADRESH
	movlw	1
	movwf	Counter
	clrf	Speed
Main;[COLOR="Red"]
	goto	Main
    bcf		INTCON,TMR0IF	;
	retfie	FAST[/COLOR]
	END
Hi AtomSoft, i just test your code got some errors like that:
Warning[207] D:\5-8\STEPPER\MAIN1.ASM 7 : Found label after column 1. (SW)
Warning[205] D:\5-8\STEPPER\MAIN1.ASM 12 : Found directive in column 1. (ORG)
Error[113]   D:\5-8\STEPPER\MAIN1.ASM 68 : Symbol not previously defined (myFlag)
Error[113]   D:\5-8\STEPPER\MAIN1.ASM 70 : Symbol not previously defined (myFlag)
Error[113]   D:\5-8\STEPPER\MAIN1.ASM 436 : Symbol not previously defined (myFlag)
Try This:
		CBLOCK	0x000
		myFlag
		ENDC
		ORG	0x0000
	bra Initialize
		ORG	0x0008
Initialize:
	movwf	TRISD
	movwf	OSCCON
	movwf	ADCON1
	movwf	ADCON2
	movwf	PR2
	movwf	T0CON
	clrf	PORTC
	movwf	ADCON0
	movlw	0x07
	clrf	CCPR1L
	clrf	CCPR2L
	movwf	CCP1CON
	movlw	0xE0
	clrf	Mode
	clrf	ADRESH
	movlw	1
	movwf	Counter
	clrf	Speed
Main:
	goto	Main
HighInt:
    bcf		INTCON,TMR0IF	;
	retfie	FAST
	END
Try This:
		CBLOCK	0x000
		myFlag
		ENDC
		ORG	0x0000
	bra Initialize
		ORG	0x0008
Initialize:
	movwf	TRISD
	movwf	OSCCON
	movwf	ADCON1
	movwf	ADCON2
	movwf	PR2
	movwf	T0CON
	clrf	PORTC
	movwf	ADCON0
	movlw	0x07
	clrf	CCPR1L
	clrf	CCPR2L
	movwf	CCP1CON
	movlw	0xE0
	clrf	Mode
	clrf	ADRESH
	movlw	1
	movwf	Counter
	clrf	Speed
Main:
	goto	Main
HighInt:
    bcf		INTCON,TMR0IF	;
	retfie	FAST
	END
thanks bro
bt new problem
Error - section '.org_1' can not fit the absolute section. Section '.org_1' start=0x00000008, length=0x000002d4
Errors : 1
did you place anything between:
		ORG	0x0000
	bra Initialize
        ;DO NOT PLACE ANYTHING HERE
		ORG	0x0008
