Hi folks
i have just taken delivery of my new linear actuator.The linear actuator is rated at 0.8-6AMPS (max load).Unfortunatley,the DPDT rocker switch attached to is 6AMP 250 VAC.Undoubtedly, the amps will reduce when it is used with 12V Dc .What will be the amps if i use it for the 12VDC linear actuator.
At half load ,does the current proportionally reduce to 3AMP?
NB.CAPTION: 'AC AMP TO DC AMP'.
