AC unit starting current too high
Tajudding
I have an AC split unit with 2.25 HP
Whenever the AC is started , the fan starts normally but when the compressor starts to run, the protection fuse trips.
I replaced the fuse but same problem
The fuse is 26 amp rating
The AC used to run normally for 5 years under the same fuse
What are the reasons that might lead to draw that high starting current?
Regards
Tajuddin
Yes, Particularly if it happens to have a start cap as well as a run cap, the start cap is only intermittent rated.
Max.
