I’m giving a square wave input to an inverter transformer using push pull method.
Frequency is 50Hz.
Transformer is 8.5V - 0 - 8.5V / 230V.
Battery voltage is 12V
What I want to know is
If I give 10mS ON time to each transistor, then what will be the output voltage?
If I give 5mS ON time to each transistor, then what will be the output voltage?
I need the relationship between time & output voltage.
Frequency is 50Hz.
