active filter using lpv324
pushpa
i have attached the circuit which i am using in my design for sensing the voltage and current using LPV324 and ina200
but not able to get the output ...
can anyone solve the problem
  • SCHEMATIC1 _ Battery-measuremen.pdf
What is the battery voltage?
You have an attenuator from the battery voltage to the input of an opamp.
The opamp has a supply voltage of 5v, if the battery voltage is greater than 7.xx volts the opamp will saturate and the output will go to the +ve rail.
How are you measuring the battery current?
Where is the sense resistor?
I do not understand how the current measurement circuit is supposed to work.
hai,
thanks for reply...
here iam using current sensing resistor between CHRG_I & ground .
using atmega88 ADC channel connected to BAT_I & BAT_I.
I don't see PV_I in the schematic. As a matter of fact I don't see any negative voltage in the schematic. You may need to draw the battery and charger into the diagram along with all voltages.
Current sensing
Please find the schematic attached..... if any thing wrong please guide me i am getting negative voltages on current sensing channel (PV_I ) while charging
  • Binder1.pdf
