richard_maven
Hello all,
I have a problem with one of my active studio monitors. I have them for many years, and it has this problem for a long time, but it's getting worse now. So, specially during winter and colder times, when I power it up, after being off for at least some hours, the power light lights up but there is no sound. Sometimes there is a very soft occasional rattle/noise. After 1-5 minutes a loud pop/bang happens and everything is fine afterwards, it starts working normally without any artifact. After that loud bang it plays perfectly for as long as it is on or warm.
This behaviour does not happen always, maybe 30% of the times I power it up (which is daily).
It's not an external thing, no external signal or power problem - I have the other monitor to test out everything.
When I power them up and this thing happens, if I increase the volume to max I can hear a very soft "pff" sound on the good one and nothing on this one (tweeter or woofer), so I assume the problem is probably on the power amp or the power supply - there is no power arriving at the tweeter/woofer. If it was in the pre amp, the power amp alone at max level would emit some noise, right? Also, by looking at the the schematics, the problem seems to be at the power supply part - this is a bi-amp system, so I suppose if there was some problem in the power amp phase, at least one of the drivers would play something, and they would not recover and return to normality exactly at the same time, right?
The problematic monitor has another weird behaviour - most times, after turning it off, there is a weird discharge noise. I assume this is some capacitor discharging. Might be a clue, I do not know.
It's tricky to test this because it doesn't happen everytime nor for a specific period, and I do not know it it is indeed happening if I remove the board from the case and disconnect the tweeter/woofer.
No capacitors are bulged. No visual clues.
I have already changed the HOT transistor and the power capacitor in the power supply, but I still got the problem.
What should I substitute next? I was going to start with the power supply capacitors/resistors.
The schematics for the power and pre amp and power supply are attached.
Cheers
Cheers
