skeeterb
I need help with a formula for the ADC of a PIC 16F877A. I want to use it to adjust the timing in milliseconds instead of seconds. I tried a formula which I have gotten before and used it in a few of my programs I have designed that use the ADC to control timing. The formula I have currently goes from 0 - 60 seconds, but I need to go from 0 - 1000 ms. The formula I have is
(Result + 1) / 17. I have tried using a /1000 but it only works for the lower settings. Can anyone suggest a formula that I can use? Thanks for your help. I am posting the code for the program below.
#define MX_PIC
//Defines for microcontroller
#define P16F877A
#define MX_EE
#define MX_EE_TYPE2
#define MX_EE_SIZE 256
#define MX_SPI
#define MX_SPI_C
#define MX_SPI_SDI 4
#define MX_SPI_SDO 5
#define MX_SPI_SCK 3
#define MX_UART
#define MX_UART_C
#define MX_UART_TX 6
#define MX_UART_RX 7
#define MX_I2C
#define MX_MI2C
#define MX_I2C_C
#define MX_I2C_SDA 4
#define MX_I2C_SCL 3
#define MX_PWM
#define MX_PWM_CNT 2
#define MX_PWM_TRIS1 trisc
#define MX_PWM_1 2
#define MX_PWM_TRIS2 trisc
#define MX_PWM_2 1
//Functions
#define MX_CLK_SPEED 5000000
#ifdef _BOOSTC
#include <system.h>
#endif
#ifdef HI_TECH_C
#include <pic.h>
#endif
//Configuration data
#ifdef _BOOSTC
#pragma DATA 0x2007, 0x3ffa
#endif
#ifdef HI_TECH_C
__CONFIG(0x3ffa);
#endif
//Internal functions
#include "C:\Flowcode V4\FCD\internals.h"
//Macro function declarations
//Variable declarations
char FCV_SWITCH1;
char FCV_MODESET;
char FCV_SWITCH2;
short FCV_RETURNDELAY;
char FCV_COUNT;
char FCV_GOINGUP;
//Macro implementations
void main()
//Initialisation
adcon1 = 0x07;
//Interrupt initialisation code
option_reg = 0xC0;
//Comment:
//This program is supposed to as closely as possible the color changes
//in the plumbob that hangs above your sims in the Electronic Arts "The
//Sims" games. It's not exactly like you would see in the game, but I
//worked it to get as close as I could using a fairly simple program.
//Comment:
//Your mood starts at the highest level, which is full green. The mood
//tends to go down as needs are not met or as in "The Sims 3" game, you
//get bad moodlets, which decrease your mood.
//Calculation
//Calculation:
// Count = 0
// ReturnDelay = 1000
FCV_COUNT = 0;
FCV_RETURNDELAY = 1000;
//Comment:
//The above command sets the mood to full green and sets the delay at
//which the program waits until it can move on to its next command. I
//thought about using an ADC and trying to figure out a formula to allow
//to adjust the timing, but still haven't worked it out yet.
//Loop
//Loop: While 1
while (1)
//Decision
//Decision: Modeset > 0?
if (FCV_MODESET > 0)
//Connection Point
//Connection Point: [A]: A
FCC_Main_A:
//Input
//Input: A1 -> Switch2
trisa = trisa | 0x02;
FCV_SWITCH2 = ((porta & 0x02) == 0x02);
//Decision
//Decision: Switch2 > 0?
if (FCV_SWITCH2 > 0)
//Decision
//Decision: Count = 0?
if (FCV_COUNT == 0)
//Goto Connection Point
//Goto Connection Point: [A]: A
goto FCC_Main_A;
} else {
//Calculation
//Calculation:
// Count = Count - 1
FCV_COUNT = FCV_COUNT - 1;
//Decision
//Decision: GoingUp > 0?
if (FCV_GOINGUP > 0)
} else {
//Calculation
//Calculation:
// GoingUp = 1
FCV_GOINGUP = 1;
} else {
//Input
//Input: A0 -> Switch1
trisa = trisa | 0x01;
FCV_SWITCH1 = ((porta & 0x01) == 0x01);
//Decision
//Decision: Switch1 > 0?
if (FCV_SWITCH1 > 0)
//Decision
//Decision: Count = 8?
if (FCV_COUNT == 8)
goto FCC_Main_A;
} else {
//Calculation
//Calculation:
// Count = Count + 1
FCV_COUNT = FCV_COUNT + 1;
//Decision
//Calculation
//Calculation:
// GoingUp = 0
FCV_GOINGUP = 0;
} else {
goto FCC_Main_A;
//Switch
//Switch: Count?
switch (FCV_COUNT)
case 1:
//Output
//Output: 0x77 -> PORT B
trisb = 0x00;
portb = 0x77;
//Output
//Output: 0x11 -> PORT C
trisc = 0x00;
portc = 0x11;
//Delay
//Delay: ReturnDelay ms
delay_ms(FCV_RETURNDELAY);
break;
case 2:
//Output
//Output: 0x33 -> PORT B
trisb = 0x00;
portb = 0x33;
//Output
//Output: 0x33 -> PORT C
trisc = 0x00;
portc = 0x33;
//Delay
break;
case 3:
//Output
//Output: 0x11 -> PORT B
trisb = 0x00;
portb = 0x11;
//Output
//Output: 0x77 -> PORT C
trisc = 0x00;
portc = 0x77;
//Delay
break;
case 4:
//Decision
//Output
//Output: 0 -> PORT D
trisd = 0x00;
portd = 0;
//Output
//Output: 0xFF -> PORT C
trisc = 0x00;
portc = 0xFF;
} else {
//Output
//Output: 0 -> PORT B
trisb = 0x00;
portb = 0;
//Output
trisc = 0x00;
portc = 0xFF;
//Delay
break;
case 5:
//Output
//Output: 0x11 -> PORT D
trisd = 0x00;
portd = 0x11;
//Output
trisc = 0x00;
portc = 0x77;
//Delay
break;
case 6:
//Output
//Output: 0x33 -> PORT D
trisd = 0x00;
portd = 0x33;
//Output
trisc = 0x00;
portc = 0x33;
//Delay
break;
case 7:
//Output
//Output: 0x77 -> PORT D
trisd = 0x00;
portd = 0x77;
//Output
trisc = 0x00;
portc = 0x11;
//Delay
break;
case 8:
//Output
//Output: 0xFF -> PORT D
trisd = 0x00;
portd = 0xFF;
//Output
//Output: 0 -> PORT C
trisc = 0x00;
portc = 0;
//Delay
break;
default:
//Decision
//Output
//Output: 0xFF -> PORT B
trisb = 0x00;
portb = 0xFF;
//Output
trisc = 0x00;
portc = 0;
//Calculation
//Calculation:
// GoingUp = 0
FCV_GOINGUP = 0;
} else {
//Output
trisb = 0x00;
portb = 0xFF;
//Decision
//Decision: Modeset = 1?
if (FCV_MODESET == 1)
} else {
//Calculation
//Calculation:
// Modeset = 1
FCV_MODESET = 1;
//Delay
mainendloop: goto mainendloop;
void MX_INTERRUPT_MACRO(void)
