ADc Suggestion.
lord loh.
I came across a temperature sensor called **broken link removed**which is supposed to give 0mv to 1v across 0c to 155c (10mv/c) output corresponging to the ambient temperature.
Suppose I try to make a digital temperature display for ambient temperature, I guess I would need an ADc to display the voltage in the form of temperature.
Could anyone suggest me a simple and inexpensive ADc.
All I want to do is to display it on a 7 segment display. I might use 7447 displays and not microcontrollers.
By far the cheapest and easiest way is to use a PIC (or other micro-controller), an 8 bit ADC is likely to cost more than a PIC containing a 10 bit one!.
The ATMEL ATmega8535 has an inbuilt ADC which has a conversion time of 60 micro seconds. This shall give a maximum sampling of not more than 16.666 KHz.
Do the expensive dedicated ADc give better results? The inbuilt ADcs shall do for a temperature sensor but to build a Digital Storage Oscilloscope?
Could you suggest a few microcontrollers with better ADcs?
