Hi everyone
I am using DSPIC33FJ256MC710-I/PT and my compiler is MiKroC pro for DSpic I want to scan 2 ADC pin (AN17 , AN18), and as we know we have to use DMA to scan simultaneously, here is my code but when I program my micro controller I faced '0'
/// Setup of LCD////
sbit LCD_RS at LATF8_bit;
sbit LCD_EN at LATD3_bit;
sbit LCD_D4 at LATC13_bit;
sbit LCD_D5 at LATD0_bit;
sbit LCD_D6 at LATD2_bit;
sbit LCD_D7 at LATF7_bit;
sbit LCD_RS_Direction at TRISF8_bit;
sbit LCD_EN_Direction at TRISD3_bit;
sbit LCD_D4_Direction at TRISC13_bit;
sbit LCD_D5_Direction at TRISD0_bit;
sbit LCD_D6_Direction at TRISD2_bit;
sbit LCD_D7_Direction at TRISF7_bit;
dma unsigned int dma_bufferA[24][4] absolute 0x7800;//Offset 0 DMA_START_ADDRESS = 0x7800;
//dma unsigned int dma_bufferB[24][4] absolute 0x7808;//Offset 8
dma unsigned int dma_bufferB[24][4] absolute 0x7A00;//Offset 200
unsigned int DmaBuffer = 0;
unsigned int ch17=0;
unsigned int ch18=0;
int flag = 0;
char str[16];
char str_1[16];
void InitADC(){
////// ADC config/////
AD1CON1bits.FORM = 0; // Data Output Format: UnSigned Integer (Q15 format) Figure 16-14: ADC Output Format 70183D.pdf//
AD1CON1bits.SSRC = 7; // Internal counter ends sampling and starts conversion (auto-convert)
AD1CON1bits.ASAM = 1; // Sampling begins when SAMP bit is set (for now)
AD1CON1bits.AD12B = 1; // 12-bit ADC operation
AD1CON1bits.ADDMABM = 0; // DMA buffers are built in scatter/gather mode
AD1CON2bits.VCFG=0; //Vref+=AVDD Vref-=AVSS//
AD1CON2bits.SMPI = 1; // (NUM_CHS2SCAN-1); // 2 ADC Channel is scanned
AD1CON2bits.CHPS = 0; // Converts CH0/CH1 When AD12B = 1, CHPS<1:0> is: U-0, Unimplemented, Read as ‘0’
AD1CON2bits.CSCNA=1; //Scan inputs // Scan Input Selections for CH0+ during Sample A bit
AD1CON3bits.ADRC = 0; // ADC Clock is derived from Systems Clock
AD1CON3bits.SAMC = 2; // Auto Sample Time = 2*Tad
AD1CON3bits.ADCS = 3; // ADC Conversion Clock Tad=Tcy*(ADCS+1)= (1/40M)*3 = 75ns (13.3Mhz)
// ADC Conversion Time for 10-bit Tc=14*Tad = 900ns (1.1MHz)
//for 500 Khz sampling in 12-bit 1/500KHz=2*10^-6=200 ns
//200ns=14Tad-->Tad=142ns---> ADCS+1=40M*142ns=5.71--> ADCS=~4
AD1CON4bits.DMABL = 2; // Each buffer contains 4 words
//AD1CSSH/AD1CSSL: A/D Input Scan Selection Register
///??? AD1CHS0bits.CH0SB = 0b10110; //17=10001 22=0b10110 // MUXA +ve input selection (AN0) for CH0
AD1CHS0bits.CH0NB = 0; // MUXA -ve input selection (Vref-) for CH0
AD1CSSHbits.CSS17=1; // Enable AN17 for channel scan
AD1CSSHbits.CSS18=1; // Enable AN18 for channel scan
//AD1CSSH=0x40;//0x2; //ADC1 INPUT SCAN SELECT REGISTER HIGH
AD1CSSL=0; //ADC1 INPUT SCAN SELECT REGISTER Low
IFS0bits.AD1IF = 0; // Clear the A/D interrupt flag bit
IEC0bits.AD1IE = 0; // Do Not Enable A/D interrupt
AD1CON1bits.ADON = 1; // Turn on the A/D converter
// DMA0 configuration
// Direction: Read from peripheral address 0-x300 (ADC1BUF0) and write to DMA RAM
// AMODE: Peripheral Indirect Addressing Mode
// MODE: Continuous, Ping-Pong Mode
// IRQ: ADC Interrupt
void initDma0(void)
DMA0CONbits.AMODE = 2; // Configure DMA for Peripheral indirect mode
DMA0CONbits.MODE = 2; // Configure DMA for Continuous Ping-Pong mode
DMA0PAD=(int)&ADC1BUF0;
DMA0CNT = 7; //(SAMP_BUFF_SIZE*NUM_CHS2SCAN)-1;
DMA0REQ = 13; // Select ADC1 as DMA Request source
// DMA0STA = __builtin_dmaoffset(BufferA);
// DMA0STB = __builtin_dmaoffset(BufferB);
DMA5STA = &dma_bufferA; // A 16-bit DMA RAM Primary Start Address Offset
DMA5STB = &dma_bufferB; //A 16-bit DMA RAM Secondary Start Address
// DMA0STA = &dma_bufferA; // A 16-bit DMA RAM Primary Start Address Offset
// DMA0STB = &dma_bufferB; //A 16-bit DMA RAM Secondary Start Address
IFS0bits.DMA0IF = 0; //Clear the DMA interrupt flag bit
IEC0bits.DMA0IE = 1; //Set the DMA interrupt enable bit
DMA0CONbits.CHEN=1; // Enable DMA
void Timer1Interrupt() iv IVT_ADDR_DMA5INTERRUPT
if(DmaBuffer == 0)
ch17=&dma_bufferA[17][4];
ch18=&dma_bufferA[18][4];
// ProcessADCSamples(&BufferA[18][0]);
else
ch17=&dma_bufferB[17][4];
ch18=&dma_bufferB[17][4];
//ProcessADCSamples(&BufferB[17][0]);
// ProcessADCSamples(&BufferB[18][0]);
DmaBuffer ^= 1;
LATF.F4=~LATF.F4;
IFS0bits.DMA0IF = 0; // Clear the DMA0 Interrupt Flag
void main() {
//AD1PCFGH/AD1PCFGL: Port Configuration Register
AD1PCFGL=0xFFFF;
AD1PCFGH=0xFFFF;
AD1PCFGHbits.PCFG17 = 0; // AN17 as Analog Input
AD1PCFGHbits.PCFG18 = 0; // AN18 as Analog Input
PORTA=0;
PORTC=0;
TRISA.F6= 1;
TRISA.F7= 1;
TRISF.F4= 0;
TRISF.F5= 0;
TRISB.F12= 0;
TRISB.F13= 0;
TRISC.F2= 1; // AN17
TRISC.F3= 1; // AN18
///////////////PLL configue////////
// Configure Oscillator to operate the device at 40Mhz
// Fosc= Fin*M/(N1*N2), Fcy=Fosc/2
// Fosc= 8M*40/(2*2)=80Mhz for 8M input clock
OSCCONbits.COSC=0x03; //0b 011 Primary oscillator (XT, HS, EC) with PLL
OSCCONbits.OSWEN=0x1; //
CLKDIVbits.PLLPRE=0; // N1=2 N1=PLLPRE+2
CLKDIVbits.PLLPOST=0; // N2=2 N2=2*(PLLPost+1)
PLLFBDbits.PLLDIV=38; // M=40 M=PLLDIV+2
////////////// Disable Watch Dog Timer////////
RCONbits.SWDTEN=0; // Disable Watch Dog Timer
Lcd_init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // CLEAR display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Out(1,1,"Hello");
delay_ms(1000);
InitAdc(); // Initialize the A/D converter to convert Channel 5
InitDma0(); // Initialise the DMA controller to buffer ADC data in conversion order
while(1){
intToStr(ch17,str);
Lcd_Out(1,1,str);
intToStr(ch18,str_1);
Lcd_Out(1,2,str_1);
Delay_ms(50);
// LATF.F4=0;
LATF.F5=1;
LATB.F12=0;
LATB.F13=1;
delay_ms(50);
// LATF.F4=1;
LATF.F5=0;
LATB.F12=1;
LATB.F13=0;
Could you please help me what my fault is?
Is there anybody have example the ADC to DMA and showing on LCD in dspic?
Thank you in advance
Kind regards
int flag = 0;
char str[16];
char str_1[16];
void InitADC(){
void initDma0(void)
if(DmaBuffer == 0)
else
DmaBuffer ^= 1;
LATF.F4=~LATF.F4;
void main() {
AD1PCFGL=0xFFFF;
AD1PCFGH=0xFFFF;
PORTA=0;
PORTC=0;
TRISA.F6= 1;
TRISA.F7= 1;
TRISF.F4= 0;
TRISF.F5= 0;
TRISB.F12= 0;
TRISB.F13= 0;
delay_ms(1000);
while(1){
intToStr(ch17,str);
Lcd_Out(1,1,str);
Lcd_Out(1,2,str_1);
Delay_ms(50);
// LATF.F4=0;
LATF.F5=1;
LATB.F12=0;
LATB.F13=1;
delay_ms(50);
// LATF.F4=1;
LATF.F5=0;
LATB.F12=1;
LATB.F13=0;
Kind regards
