ADC0808 channel selection and interferance between channels problem.
hi friends,
i am getting 3 analog signals at the inputs of ADC0808 and i am displaying it on LCD. they are voltage current and temperature signals. the problem is that when i vary one of the analog input it also effects the data from other inputs. that is if i vary voltage it resutls in the variation of voltage data, current data and temprature data on tha Screen of LCD. i tried my best to isolate it from each other by putting delays and clearing the arrays and data memory locations but the problem is as it is... please help me to rectify my problem...
following is my code:
#include <reg52.h>
 #define select P3
 #define Port P2  // control port
 #define adc_input P1
 #define data_port P0  // data from microcontroller to LCD
 #define sec 50
 #define scan 10
 sbit ADC_A=Port^0;	//ADC
 sbit ADC_B=Port^1;	//ADC
 sbit RS=Port^7;  		//LCD
 sbit E=Port^5;		   //LCD
 sbit ctl=Port^6;		  //LCD
 sbit SC=Port^4;   //ADC
 sbit CLK=Port^3;  //ADC
 sbit ALE=Port^2;  //ADC
 sbit v28=select^4; // carger 28v selected
 sbit v14=select^5;
 sbit v7=select^6;
 sbit off=select^7;
 sbit intr=select^2;
 sbit c28=select^0;
 sbit c14=select^1;
 sbit c7=select^3;
unsigned int test_intermediate3=0, test_final=0, select_mem=0, x=0;
unsigned int test_intermediate1[scan], test_intermediate2[3]={0,0,0};
unsigned char temp[]={"Temp:  "}, vna[]={" Volt:    Amp:  "},  hnm[]={"  hr   min     %"}, bnc[]={"Backup:  %Charge"};
		void delay(unsigned int msec)
			int i,j;
			for(i=0; i==msec; i++)
				for(j=0; j==1275; j++);
		void long_delay(unsigned int second)
		   int i,j;
		   for (j=0; j<second ; j++)
		  		 for (i=0; i<0xffff; i++);
		//---------------- timer 0 interrupt----------------
		void timer0() interrupt 1
					CLK=~CLK;		// Toggle port bit p3.5
					TR0=0;         // stop timer
					TH0=0xff;	    // 500hz clock for adc
					TL0=0xff;
					TR0=1;			// start timer
		 void switch2(void)
  		if (v7==1 & v14==0 & v28==0)
				c7=1; c14=0; c28=0;
		else
		if(v14==1 & v7==0 & v28==0)
				c14=1; c7=0; c28=0;
		else
		if (v28==1 & v7==0 & v14==0)
				c28=1; c14=0; c7=0;
	   //---------------- External 0 interrupt----------------
		void switching() interrupt 0
				     intr=1;
					 delay(sec*4);
		   		   select = select_mem;
					  intr=1;
					   delay(sec*4);
					   	if(v28==0 & v14==0 & v7==0 & off==1)
				  				{ off=0; v7=1; v28=0; v14=0; }
				    else
                        if(v28==0 & v14==0 & v7==1 & off==0)		//e1
                                { v7=0; v14=1; v28=0; off=0; }
					else
						if(v28==0 & v14==1 & v7==0 & off==0)		 //e2
						        { v14=0; v28=1; v7=0;  off=0; }
					else
						if(v28==1 & v14==0 & v7==0 & off==0)		 //e3
					   			{ v28=0; v14=0; v7=0; off=1; }
				delay(sec*4);
				intr=1;
				c7=0; c14=0; c28=0;
				delay(sec*4);
			   	select_mem = select;
				long_delay(10);
				 switch2();
		//.................. LCD .................
		void lcd_cmd( unsigned int item )
			data_port=item;  //command on data port p0 of lcd
			RS=0;            // selecting command register of lcd
		//	RW=0;
			E=1;
			delay(1);
			E=0;
		void lcd_data( unsigned int item )
			data_port=item;  //data on data port p0 of lcd
			RS=1;            // selecting data register of lcd
		//	RW=0;
			E=1;
			delay(1);
			E=0;
	  //----------- custom character Generation for Degree symbol-----------
	  void shape()
			lcd_cmd(64); 		// first location in CGRAM
			delay(sec);
			lcd_data(2);
			delay(sec);
			lcd_data(5);
			delay(sec);
			lcd_data(2);
			delay(sec);
			lcd_data(0);
			delay(sec);
			lcd_data(0);
			delay(sec);
			lcd_data(0);
			delay(sec);
			lcd_data(0);
			delay(sec);
			lcd_data(0);
			delay(sec);
	  //-------------------- for volt symbol-----------------
	   void shape2()
			lcd_cmd(72); 		// second location in CGRAM
			delay(sec);
			lcd_data(0);
			delay(sec);
			lcd_data(0);
			delay(sec);
			lcd_data(17);
			delay(sec);
			lcd_data(17);
			delay(sec);
			lcd_data(17);
			delay(sec);
			lcd_data(10);
			delay(sec);
			lcd_data(4);
			delay(sec);
			lcd_data(0);
			delay(sec);
	 //---------------------- for current symbol-------------------
	  void shape3()
			lcd_cmd(80); 		// Third location in CGRAM
			delay(sec);
			lcd_data(0);
			delay(sec);
			lcd_data(0);
			delay(sec);
			lcd_data(4);
			delay(sec);
			lcd_data(10);
			delay(sec);
			lcd_data(17);
			delay(sec);
			lcd_data(31);
			delay(sec);
			lcd_data(17);
			delay(sec);
			lcd_data(0);
			delay(sec);
	  //..... Converting binary value of ADC to ASCII value of LCD for Temprature........
	  void convert()
	  		int s;
			test_final=(((9*test_intermediate3)/5)+32);			 // Farenhite conversion
			s=test_final/100;
			test_final=test_final%100;
			lcd_cmd(0xc5);
			delay(sec);
			if (s!=0)
				lcd_data(s+48);	//c5
				delay(sec);
			else
				lcd_cmd(0x06);
				delay(sec);
		  s=test_final/10;
		  test_final=test_final%10;
		  lcd_data(s+48);	   //c6
		  delay(sec);
		  lcd_data(test_final+48);	//c7
		  delay(sec);
		  lcd_data(0);				 // space for degree symbol
		  delay(sec);
		  lcd_data('F');
		  delay(sec);
		  lcd_data(' ');
		  delay(sec);
		//------------------- for Celcius scale----------------
		  test_final=test_intermediate3;
		  s=test_final/100;
			lcd_cmd(0xcB);
			delay(sec);
			if (s!=0)
				  lcd_data(s+48);	// 1st digit MS
					delay(sec);
			else
				  lcd_cmd(0x06);
					delay(sec);
		  s=test_final/10;			 // 2nd digit
		  test_final=test_final%10;	 // 3rd digit LS
		  lcd_data(s+48);  //89
		  delay(sec);
		  lcd_data(test_final+48);	 //88
		  delay(sec);
		  delay(sec);
		  lcd_data('C');
		  delay(sec);
		   lcd_data(' ');
		  delay(sec);
		 // Converting binary value of ADC to ASCII value of LCD for volts
		 void  Convert2()
		 	int s;
	 //.................... Voltage conversion ............................
		 test_final=test_intermediate3/5;
			s=test_final/100;
			 lcd_cmd(0x85);
			delay(sec);
			if (s!=0)
				lcd_data(s+48);
				delay(sec);
			else
				lcd_cmd(0x06);
				delay(sec);
		  s=test_final/10;
		  lcd_data(s+48);
		  delay(sec);
		  delay(sec);
		  lcd_data(1);
		  delay(sec);
		   lcd_data(' ');
		  delay(sec);
		 void  Convert3()
		 	int s;
	//.................... current conversion ............................
			s=test_final/100;
			  lcd_cmd(0x8D);
			delay(sec);
			if (s!=0)
				lcd_data(s+48);
				delay(sec);
			else
				lcd_cmd(0x06);
				delay(sec);
		  s=test_final/10;
		  lcd_data(s+48);
		  delay(sec);
		  delay(sec);
		  lcd_data(2);
		  delay(sec);
	  //.........--------.......Main Program.......-------........
		   void main()
		   		int i,j,k,l,m,n;
				adc_input=0xff; // making p1 as input port
				TMOD=0x01;	   // timer 0,  mode 1
				TL0=0xff;
				TR0=1;         // timer start
				IE=0x83;		// interrupt enable ; timer interrupt, external interrupt and globle interrupt.
			v28=0; v14=0; v7=0; off=1;  // intializing charger selection to 0V
			c28=0; c14=0; c7=0;
			intr=1;
			  delay(sec);
				lcd_cmd(0x38);		// initializing LCD module
				delay(sec);
				lcd_cmd(0x0c);
				delay(sec);
				lcd_cmd(0x01);
				 delay(sec);
				lcd_cmd(0x06);
				delay(sec);
	//......... volt and ampere display........
	       lcd_cmd(0x80);
		   	delay(sec);
			for(i=0; vna[i]!='\0'; i++)
					lcd_data(vna[i]);
					delay(sec);
	//..........- Back up and %Charge display ----........
				lcd_cmd(0x90);
			    delay(sec);
			for(i=0; bnc[i]!='\0' ; i++)
					lcd_data(bnc[i]);
					delay(sec);
	    //......... ----Temp: display-----........
			lcd_cmd(0xc0);
		 	delay(sec);
			for(i=0; temp[i]!='\0' ; i++)
					lcd_data(temp[i]);
					delay(sec);
	//.............- hour and minute display ------...........
		    lcd_cmd(0xD0);
		   	delay(sec);
			for(i=0; hnm[i]!='\0'; i++)
					lcd_data(hnm[i]);
					delay(sec);
				while(1)
				//;;;;;;;;;;;;;;;;;;;;;;;;;;;;;Temprature samples;;;;;;;;;;;;;;;;;;;;;;
					   test_intermediate3=0;
							test_final=0;
						test_intermediate2[0]=0;
						test_intermediate2[1]=0;
						test_intermediate2[2]=0;
						for(j=0;j<3;j++)
							for(i=0;i<scan;i++)
							{	   ctl=0;
								     delay(10);
								   ADC_A=0;
								   ADC_B=0; // channel 0 is selected   ; pin 26 of ADC
									delay(200);
									ALE=0;
									SC=0;
									delay(1);
									 ALE=1;
									 delay(1);
									 SC=1;
									 delay(1);
									 ALE=0;
									 delay(1);
									 SC=0;
									 delay(200);
									 test_intermediate1[i]=adc_input/scan;
							for(i=0;i<scan;i++)
							test_intermediate2[j]+=test_intermediate1[i];
						test_intermediate2[0]=test_intermediate2[0]/3;
						test_intermediate2[1]=test_intermediate2[1]/3;
						test_intermediate2[2]=test_intermediate2[2]/3;
						test_intermediate3=test_intermediate2[0] + test_intermediate2[1] + test_intermediate2[2];
						convert();
						shape();
					long_delay(1);
					ctl=1;
					delay(10);
					  ADC_A=1;
					 ADC_B=0; // channel 1 is selected for voltage
			 //;;;;;;;;;;;;;;;;;  Voltage samples;;;;;;;;;;;;;;;;;;;;;;;;;
				   test_final=0;
					  	for( k=0;k<3;k++)
							for(l=0;l<scan;l++)
									delay(10);
								   ADC_A=1;
									delay(200);
									ALE=0;
									SC=0;
									delay(1);
									 ALE=1;
									 delay(1);
									 SC=1;
									 delay(1);
									 ALE=0;
									 delay(1);
									 SC=0;
									 delay(200);
									 test_intermediate1[l]=adc_input/scan;
							for(i=0;i<scan;i++)
							test_intermediate2[k]+=test_intermediate1[i];
						 Convert2();
						 	shape2();
						long_delay(1);
					  ADC_A=0;
					 ADC_B=1; // channel 2 is selected for	current
		//;;;;;;;;;;;;;;;;;  Current samples;;;;;;;;;;;;;;;;;;;;;;;;;
							test_final=0;
					  	for( m=0;m<3;m++)
							for( n=0;n<scan;n++)
									delay(10);
								   ADC_A=0;
									delay(200);
									ALE=0;
									SC=0;
									delay(1);
									 ALE=1;
									 delay(1);
									 SC=1;
									 delay(1);
									 ALE=0;
									 delay(1);
									 SC=0;
									 delay(200);
									 test_intermediate1[n]=adc_input/scan;
							for(i=0;i<scan;i++)
							test_intermediate2[m]+=test_intermediate1[i];
						 Convert3();
						 	shape3();
						long_delay(1);
and here is my circuit diagram..
thanking you in anticipation.
regards
Qaisar azeemi.
I've done a simulation..... You can't just clock the clock pin on the ADC when you want data.. It needs a constant clock. If you place a digital clock source on the clock pin It works fine
(apart from the horrendous mapping)
i cant understand fully...
you mean to say i should use a 555timer IC to get a continuous clock??? i think i am using a continuous clock as i am generating it using timer 0 interrupt... ?????
my above problem is solved Mr Rogers. :)
it was due to the previously converted data added to the the new scan. i just write an extra() function to put 00000000 to the output port of ADC0808; and call extra on next channel scan; thus to erase the previously converted data and prevent it to be added to the data of next channel hence the co-channel logical interference is eleminated...
now i fall in to another Logical problem ... that the analog data for voltage on pin 27 channel 1 of ADC is not converted to its true value to be displayed at the output... please see the convert 2 function in my code. . . the conversion is not linear... updated code is tagged below......
#include <reg52.h>
 #define select P3
 #define sec 50
 #define scan 10
 sbit v14=select^5;
 sbit v7=select^6;
 sbit off=select^7;
 sbit intr=select^2;
 sbit c28=select^0;
 sbit c14=select^1;
 sbit c7=select^3;
			int i,j;
		   int i,j;
					TL0=0xff;
		 void switch2(void)
				c7=1; c14=0; c28=0;
		else
				c14=1; c7=0; c28=0;
		else
				c28=1; c14=0; c7=0;
				     intr=1;
					 delay(sec*4);
					  intr=1;
					   delay(sec*4);
				    else
					else
					else
				delay(sec*4);
				intr=1;
				c7=0; c14=0; c28=0;
				delay(sec*4);
			//	delay(1000);
				long_delay(10);
				 switch2();
		//	RW=0;
			E=1;
			delay(1);
			E=0;
		//	RW=0;
			E=1;
			delay(1);
			E=0;
	  void shape()
			delay(sec);
			lcd_data(2);
			delay(sec);
			lcd_data(5);
			delay(sec);
			lcd_data(2);
			delay(sec);
			lcd_data(0);
			delay(sec);
			lcd_data(0);
			delay(sec);
			lcd_data(0);
			delay(sec);
			lcd_data(0);
			delay(sec);
			lcd_data(0);
			delay(sec);
	   void shape2()
			delay(sec);
			lcd_data(0);
			delay(sec);
			lcd_data(0);
			delay(sec);
			lcd_data(17);
			delay(sec);
			lcd_data(17);
			delay(sec);
			lcd_data(17);
			delay(sec);
			lcd_data(10);
			delay(sec);
			lcd_data(4);
			delay(sec);
			lcd_data(0);
			delay(sec);
	  void shape3()
			delay(sec);
			lcd_data(0);
			delay(sec);
			lcd_data(0);
			delay(sec);
			lcd_data(4);
			delay(sec);
			lcd_data(10);
			delay(sec);
			lcd_data(17);
			delay(sec);
			lcd_data(31);
			delay(sec);
			lcd_data(17);
			delay(sec);
			lcd_data(0);
			delay(sec);
	  void convert()
	  		int s;
			s=test_final/100;
			lcd_cmd(0xc5);
			delay(sec);
			if (s!=0)
				delay(sec);
			else
				lcd_cmd(0x06);
				delay(sec);
		  s=test_final/10;
		  delay(sec);
		  delay(sec);
		  delay(sec);
		  lcd_data('F');
		  delay(sec);
		  lcd_data(' ');
		  delay(sec);
		  s=test_final/100;
			lcd_cmd(0xcB);
			delay(sec);
			if (s!=0)
					delay(sec);
			else
				  lcd_cmd(0x06);
					delay(sec);
		  delay(sec);
		  delay(sec);
		  delay(sec);
		  lcd_data('C');
		  delay(sec);
		   lcd_data(' ');
		  delay(sec);
		 void  Convert2()
		 	int s;
		 test_final=test_intermediate3/8;
			s=test_final/100;
			 lcd_cmd(0x85);
			delay(sec);
			if (s!=0)
				lcd_data(s+48);
				delay(sec);
			else
				lcd_cmd(0x06);
				delay(sec);
		  s=test_final/10;
		  lcd_data(s+48);
		  delay(sec);
		  delay(sec);
		  lcd_data(1);
		  delay(sec);
		 void  Convert3()
		 	int s;
		 test_final=test_intermediate3/2;
			s=test_final/100;
			  lcd_cmd(0x8D);
			delay(sec);
			if (s!=0)
				lcd_data(s+48);
				delay(sec);
			else
				lcd_cmd(0x06);
				delay(sec);
		  s=test_final/10;
		  lcd_data(s+48);
		  delay(sec);
		  delay(sec);
		  lcd_data(2);
		  delay(sec);
	  //,,,,,,,,,,,,,,,,,,,---cleanzing---,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
	  void extra()
		 int m,n,o;
	  					for( m=0;m<3;m++)
									delay(10);
								   ADC_A=1;
								   ADC_B=1; // channel 4 is selected
									delay(200);
									ALE=0;
									SC=0;
									delay(1);
									 ALE=1;
									 delay(1);
									 SC=1;
									 delay(1);
									 ALE=0;
									 delay(1);
									 SC=0;
									 delay(200);
							for(o=1;o<scan;o++)
							test_intermediate2[m]+=test_intermediate1[o];
						test_final=0;
		   void main()
		   		int i,j;
				TL0=0xff;
			c28=0; c14=0; c7=0;
			intr=1;
			  delay(sec);
				delay(sec);
				lcd_cmd(0x0c);
				delay(sec);
				lcd_cmd(0x01);
				 delay(sec);
				lcd_cmd(0x06);
				delay(sec);
	       lcd_cmd(0x80);
		   	delay(sec);
					lcd_data(vna[i]);
					delay(sec);
				lcd_cmd(0x90);
			    delay(sec);
					lcd_data(bnc[i]);
					delay(sec);
			lcd_cmd(0xc0);
		 	delay(sec);
					lcd_data(temp[i]);
					delay(sec);
		    lcd_cmd(0xD0);
		   	delay(sec);
					lcd_data(hnm[i]);
					delay(sec);
				while(1)
				//;;;;;;;;;;;;;;;;;;;;;; Temprature samples ;;;;;;;;;;;;;;;;;;;;;;
					   //extra();
							test_final=0;
						ADC_A=0;
						for(j=0;j<3;j++)
							for(i=0;i<scan;i++)
							{	   ctl=0;
								   delay(10);
								   ADC_A=0;
									delay(200);
									ALE=0;
									SC=0;
									delay(1);
									 ALE=1;
									 delay(1);
									 SC=1;
									 delay(1);
									 ALE=0;
									 delay(1);
									 SC=0;
									 delay(200);
							for(i=1;i<scan;i++)
						convert();
						shape();
					   extra();
					 delay(10000);
					 ADC_A=1;
				  		 test_final=0;
					  	for( j=0;j<3;j++)
							for(i=0;i<scan;i++)
								   delay(10);
								   ADC_A=1;
									delay(200);
									ALE=0;
									SC=0;
									delay(1);
									 ALE=1;
									 delay(1);
									 SC=1;
									 delay(1);
									 ALE=0;
									 delay(1);
									 SC=0;
									 delay(200);
							for(i=1;i<scan;i++)
						 Convert2();
						 shape2();
						 extra();
						 delay(10000);
					//	long_delay(1);
					  ADC_A=0;
						test_final=0;
					  	for( j=0;j<3;j++)
							for( i=0;i<scan;i++)
									delay(10);
								   ADC_A=0;
									delay(200);
									ALE=0;
									SC=0;
									delay(1);
									 ALE=1;
									 delay(1);
									 SC=1;
									 delay(1);
									 ALE=0;
									 delay(1);
									 SC=0;
									 delay(200);
							for(i=1;i<scan;i++)
						 Convert3();
						 	shape3();
							extra();
					//	long_delay(1);
						delay(10000);
Thank you very much mr rogers. :) what is SDCC??
SDCC is a free C compiler for small devices.. I like it, even though its a little harder to learn.
I found out why the clock wasn't working.... Even if you set the count to 0xFFFF... It was counting once
Instead of 500khz it was only 34khz... So the timer cant be used
I worked out that we have a 14uS maximum we need 2uS.
