Vetteman61
Hello everyone,
I greatly appreciate your help ahead of time. I have a 1971 Pontiac station wagon. It has a mechanical cooling fan on it now which is of course attached to the engine. I want to add electric fans to 1) help get a couple extra mpg 2) cure an overheating problem when the air conditioning is on. I have found online that you can get a million ways to do something from automotive forums, but they often aren't the "right" way to do things. I like to do things the best and most correct way and unfortunately wiring things to activate under particular circumstances is something I don't understand, but would like to learn.
I need to have two fans, one behind the radiator/condenser to pull air through the radiator/condenser. This fan should come on like any other automotive fan, when a certain, preset temperature is reached. Another fan will be in front of the radiator/condenser to push air through at all times any time the air conditioner is on.
Here is a picture of the general physical setup just to help with visualizing what I have described
Thank you,
Brandon
![29660267171_0178f67379_b.jpg](https://c1.staticflickr.com/9/8526/29660267171_0178f67379_b.jpg)
Thank you,
Brandon
