Hey guys I'm having a bit of trouble understanding the data I am receiving. I took a bit of time to do the other portions of my project and then came back to the touch screen. So far, I am able to read data upon the second pass through for x and y. The main problem is that the expected values should be up to 12 bits of data (max 4096), and instead I am reading values as high a 32,000.
I am using unsigned shot (UINT16) to read the data from the 16bit SPI receive buffer. The good news is that as I press up, down, left, or right, the values do increase/decrease (sometimes it can be glitchy and it gives me a lower value when I am expecting to read a higher one).
Datasheet for ADS7843
I am using C32, MPLAB X, and a pic32mx795F512H. Here is my code:
I also have a 200ms delay after I read to prevent the interrupt from the ADS7843 from triggering again. However, if it is held down longer it triggers the interrupt again.
Basically my questions are as follows:
_____________________________
1. Why am I getting higher values (higher than 4096) when I receive the 12bit data?
2. Is there anything that I am forgetting/not including when reading/writing to the ADS7843?
Thank you.
void Touch_Init(void) // Initialises the touch screen
Touch_CS = 1; // Deasserts the CS line.
Touch_PenIRQ_TRIS = 1;
// Initialize SPI hardware module pg. 206/314 of C32 user guide
// SPI Channel (set to 4), Set uC as Master, clock polarity cotrol, baud rate
// Baud Rate = BR = Fpb/(2*(SPIBRG+1)), Fpb is 1:1 => 80MHz
// Baud RAte = 80MHz/(2*(2MHz+1))=>20
SpiChnOpen(SpiChn, SPICON_MSTEN|SPICON_CKP|SPICON_MODE16|SPICON_ON,20);
Touch_CS = 0;
TDelay(); //200ns
// See pg. 6 and 9 of 18 in ADS7843 datasheet/ pg.21 of XPT2046
// S = start bit, A=addressing-input for multiplexer, MODE=selects ADC resolution PD = power down bits for idle
// Bits 0 -> 7 = S A2 A1 A0 MODE SFR/DFRnot PD1 PD0
SpiChnPutC(SpiChn, 0b10010100); // Sends the initialisation byte
dummyReadSPI=SPI4BUF; // clears the receive buffer
Touch_CS = 1;
void ReadTouchXY(void)
UINT16 readX, readY,sampleCount=0,avgCount=0;
Touch_PenIRQ_TRIS = 0; // Sets the PenIRQ to an output
Touch_PenIRQ_LAT = 0; // Drives the PenIRQ low so the diode is not forward biased
Touch_CS = 0;
TDelay(); // Asserts the CS line and gives a required delay
// Read twice to ensure data is recieved
for(sampleCount=1;sampleCount<=6;sampleCount++)
SpiChnPutC(SpiChn, 0b11010100); // Sends the control byte
SpiChnGetC(SpiChn); // Reads the dummy data to clear the receive buffer
SpiChnPutC(SpiChn, 0x00); // Sends a dummy byte in order to clock the data out
readY = SpiChnGetC(SpiChn); // Reads Y coordinates
SpiChnPutC(SpiChn, 0b10010100); // Sends the next control byte to read the other axis
readX = SpiChnGetC(SpiChn); // Reads X coordinates
coordXresult=readX;
coordYresult=readY;
Touch_CS = 1; // Deasserts the chip select line
Touch_PenIRQ_TRIS = 1; // Sets the PenIRQ to an input again
Thank you.
