Advice for MPLAB X please.
ljcox
I imported my project from MPLAB 8.92 into MPLAB X successfully but can't simulate it like I do with 8.92.
The tutorial indicates that I need a device such as PIC KIT3 between the computer & the PIC.
But I want to do it in MPLAB X only as I do in 8.92. I have not been able to find how to do this in the tutorials.
I think I may have clicked on the wrong tool. I think I chose Simulator.
The attachment shows the window at which I grind to a halt. Any advice will be appreciated.
Len,
You need to set a break point(before you run it) or hit the pause button. It is running continuously.
Edit, I see you have some delays in your code. These will take a long time to execute in the simulator so it might be an idea to rem them out.
When you set up your project, under the configuration menu make sure that you select Simulator instead of a programming device.
(BTW, this should probably not be posted in the Oshonsoft section.)
