Hello All,
I need to develop a feedback circuit to stabilize a system I have. I've attached an image to elucidate the problem.
Essentially, the system will output an Output Voltage depending on the temperature it is at (see diagram). I would like the system to remain at the state where it outputs the minimum voltage (the bottom of the dip in the graph). However, the temperature is unstable, and fluctuates on the order of KHz. An Input Voltage can be used to correct the system, increasing the Input Voltage moves the system in the opposite direction of the temperature shift.
If the function was a monotonically increasing line I could easily imagine how to build a feedback circuit for it. However, the symmetry around the minimum point makes this an unfamiliar problem for me.
I'm not familiar with control theory, I would greatly appreciate it if someone could direct me to the appropriate book chapter to read, or alternatively, direct me to an appropriate set of circuits I could utilize. I have the vague notion that a PID controller could be utilized, so if someone could also comment on that I would be very grateful.
Thanks in advance,
Thanks in advance,
