I'm trying to build a project where I need a 4PDT toggle switch. This is a 12 volt (nominal) project. I'll use an inline meter that measures voltage, amps, watts, accumulated amps used, etc..
This sellers of this meter claim it can take 50 amps continuous without a shunt. The write-up even says it can take 100 amps for short-term use. Frankly, given that the wires look like no more than 14 or 16 gauge, I doubt the claim. There are two wires that go into the meter. And two wires that go out of the meter to your load. (I bought it from someone on Flea-Bay. Paid right at $30 for it about a month ago. Now there is some selling what appears to be the same units for $9.95 - out of Hong Kong.) I've looked, but I don't see a brand name on the meter.
I have been testing this meter with an emergency light project that uses a 12 volt deep cycle battery and some LEDs. I've tested the meter's measurements with a couple of volt/ohm meters. The meter's results seem to agree with my independent meters. The verbage even says this meter can be used with a charging circuit to measure how many amps/watts/etc. are going from a solar panel (or other chargers) to your battery. This sounds like an ideal idea. I've seen several discussions on this board where people wanted to measure this.
I want to use one of these meters in a 12 volt battery circuit for a portable water system. Knowing how much I've drained the battery would be helpful while I'm out working.
I want to use the 4PDT switch to configure the meter to work for measuring output to my water pump. Then I want to use the same switch at night to reverse the circuit so the same meter can measure the input from a battery charger.
Sorry for the long intro.
Question: I see toggle switches rated for 15 amps at 120 volts. My system will be running at 12 volts. How do I figure how many amps at 12 volts would be reasonable for these switches to be able to handle?
I don't expect to do 50 amps on this project. But situations might come up where I'd want to use a toggle switch in a larger solar panel project, for example. I want to know how to determine what is a safe limit for any switches I use. Too, being able to build an electronic circuit to turn such a project on or off might be useful too.
Any input and advice on how to calculate the reasonable expected capability of such switches would be appreciated.
Bach On
(And for those who might want to measure your solar panel output, you might want to check out fleaBay. Do a search for watt meter.) I promise - I'm not involved with anyone selling these meters. But having used one, I'm impressed. Who knows how long it will hold up? And I sure wouldn't use if for 50 amps.
Bach On
