WeirdWizard
Hi guys
I am currently experimenting with a project to generate a certain amount of Kinetic energy with a flywheel driven by a small motor to drive a 10KVA/8KW 2pole generator alternator. How do I calculate the flywheel size? For example, I want to build up momentum slowly with a 0.75KW or a 1.1KW 2-pole motor, then when the flywheel reached it's required RPM, I want to be able to run the alternator at 80% capacity at least. What I want to know is how do I calculate the size and weight of the flywheel?
