The datasheet for the TDA2009A amplifier IC shows that its heatsink tab is already connected to its ground pin #6, so maybe your IC had a bad connection. It is fine to add your own wire that fixed the problem and I am glad that you discovered it.i took a wire from my input ground ran the to the ic's heat sink and all the buzzing,humming and radio stations stopped is that ok for the ic?
